Help me choose better current source
demodb
Member level 4
Member level 4
current source
which one of these is better, if we look at component characteristics and power supply?
Re: current source
If you'v read book or lecture of Allen,might you can find some .
Re: current source
The second one has higher output resistance, but worse compliance.
Re: current source
If you use the first one, when Vdd change the current will change. If you use a PNP transistor and a resistor connected to the grounded the variation are less, because the transistor absorb part of the variation and the resistor voltage remain quite constant.
Re: current source
thx, for the help guys. Did help me a lot.
