naspek
Member level 1
A voltage signal generated by a sensor conditioning circuit varies from -0.5V to +0.5V . The signal from the sensor is to be connected to the analog to digital converter which only accepts positive voltage. Design an op-amp circuit to amplify the signal 5 times and shift the signal to the positive range. The output signal after amplification and shifting should fluctuate between 0 V to 5 V. Choose the resistor value so that the dc current does not exceed 100uA
can anyone suggest which type of op amp should be used to solve this question?
