DjinnG
Newbie level 5
laptop power supply boost converter
I have built a linear regulated power supply, and have found an abundance of information on how to go about it.
Now I would like to build an SMPS that can be small enough to be portable (for a laptop).
Although the building of a linear power supply is - relatively - straightforward and there is an abundance of information on the net, I could not find any information on creating an SMPS suitable for a laptop.
The required output is 16V 4A.
What I have managed to understand so far:
1. The 230VAC input is switched to a much higher frequency (a few 100's Khz)
2. At those frequencies the stepdown transformer can be MUCH smaller due to higher impedance.
3. A buck converter is sometimes used at the output.
- What sources of information are available for this kind of project?
- Although I've tried my best, I could not find a guide to selecting a transformer for such power supplies (type, ratings, etc...).
- Is the switching applied to the raw AC or is it "flattened" out first?
- Does a buck converter require a ferrite core? (I've seen schematics that use air core and others that use ferrite)
Thanks for any help.
