Help me build a simple delay off timer
mikesmixes
I need to build a simple delay off timer. When the input is triggered (pulse only) the output must go high and stay high for a period of say 1 hour or 4 hours or selectable. When the input is triggered again, the output timing is restarted.
Any idea's? Would a 555 timer work? Not sure about the long delays.
Supply is 24Vdc.
Thanks.
Mike
Re: Delay off timer
Yes, the 555 would work. The time delay required is rather high, though. That means you have to use a good quality cap. The CMOS version of the 555 would be more suitable.
You will also need a regulator, since the supply voltage is 24V and the 555 cannot work at that voltage.
