Help me build a device with 16 USART
joebazoka
Full Member level 1
Argentina
USART expansion device
Hi, I need construct a device with 16 USART. This must be connected to a microcontroller. Anybody have idea if exist an expansion device for do this?. The porpose of this system is establish comunication with 16 remote devices. I can´t implement a bus topology because the 16 devices are commercial with TTL USART interface and I can't control the bus contention. Regards.
If you don't need the 16 devices simultaneously you can build your own multiplexer with some TTL or CPLD ? That will be much easier than using 16 UARTs.
Mik
Re: USART expansion device
if you use only assy. Communication ;
Use any high speed controller for slave processor.
Slave processor may emulate the UART using Standart I/O pin, and communicate your controller (serial or parralel.)
hi if u have complete USART PROJECT THEN PLEASE SEND ME CODING OF THE PROJECT ...I REALLY NEED IT ...PLZZZZZZZZZ
Added after 14 minutes:
if u have USRT coding then send me please.....
bibekkumarit82@gmail.com
