Help me add Tamura 3FL16-350 to a PCB layout
brosskgm
Member level 4
Member level 4
California, USA
Need help from someone that knows PCB design and can work with a .lay file. I was given a pcb file (.lay file attached in zip) for a power supply and needed a transformer to tie on to it.
I have a 3FL16-350 Tamura datasheet is attached also that I was told would be an excellent choice.
I don't understand how to work in design so if anyone can give assistance to put the Tamura on this would be great.
Thanks in advance for any help.
Bob
  • 3FL16-350 Tamura Transformer.pdf
  • 7805_7905_Voltage_Regulator.zip
Re: +/- 5V power supply.
Try this way:
Thank you so much. This will give me something to work on.
All I have to do is figure out how to get this on the PCB board.
Thanks again
Bob
On a second thought, :cool: there’ s a need to use a fusible unit in the primary circuit and maybe it’s better to rotate the LM7905 integrated circuit as this may require some small heat sinks.
Hi mister_rf,
Thank you for this.
Is there a chance you could put this in a .lay file? I have a couple small heat sinks so that's not a problem.
Thanks
Bob
---------- Post added at 16:27 ---------- Previous post was at 16:19 ----------
I do have pictures of the unit I pulled this transformer out of if that will help. It's an Adtran DSU 56/64 1997 back during the 56K internet circuit days. It was mentioned just cutting the area out and use that but not knowing enough I didn't.
I do have another one of these that I haven't tore apart yet if the complete setup is needed.
:-D
Try adjusting this PCB for the correct transformer mounting footprint …
  • test 5V_v2.rar
Ok thanks. I'll see what I can do. I'm not sure the viewer will let me do that but I'll find a way to work with it.
Thanks again
Bob
I printed out your .lay file, you have the PCB footprint perfect for the holes.
Thanks
mister-rf, where you make the PCB layout (software) n how make it 3D,? I use Eagle software, please tell me how.
I just got all pieces to put this together.
It keeps blowing the fuse. Any suggestions were to look?
I have pins 1234 on the AC in.
Thanks
Bob
:-D
I have a question about part of this.
The datasheet for the 3FL16-350 Shows pin 1 & 3 together and 2 & 4 together.
But in the datasheet Pin 3 is the last one and pin 4 is the third one, as with the out put 5 & 7 are on the ends and pin 8 is the third one.
1 5
2 6
4 8
3 7
Could this be causing it to heat up and blow the fuse?
The datasheet is attached a couple entries above. If it's not there I can send it again.
Thanks.
Bob
:-D
Yes, now I have realised my mistake. Mea culpa... Reverse transformer pins 3 and 4, also pins 7 and 8 and later try to test the circuit by connecting series some light bulb (110v/40W-60W.
I'm glad to hear it wasn't all me.
Would you be able to send a new .LAY file? I only have the viewer/printer.
Thanks
Bob
mister_rf,
Thanks. Would you by chance have an updated .LAY file?, I'm only able to read them. Can't edit them.
Thanks
Bob
Files attached. :-D
  • layout_2.rar
