Help me about Face Recognition
earlybird
Banned
Bangladesh
Hello Friends,
My thesis topic is Face Recognition. I've used Eigenface Method.
For better result what can I do? please help me.
sagar
(KUET=Khulna University of Engineering and Technology.Bangladesh)
I'm not expert in that field......but I hear about edge method from one of my friend....you can google it
Best Regards,
Salam
How does this idea come into your mind?
There is a thesis avaialble of Turk and Pentland
Please go through it ........
I am sending you a sample code from DREXEL UNIVERSITY WEBSITE
Regards
Robin
%DREXEL UNIVERSITY
%Eigenface Matlab Code
% Face recognition by Santiago Serrano
clear all
close all
clc
% number of images on your training set.
M=50;
% Chosen std and mean.
% It can be any number that it is close to the std and mean of most of the images.
um=100;
ustd=80;
% read and show image
S=[]; % img matrix
figure(1);
for i=1:M
str=strcat(int2str(i),'.bmp'); % concatenates two strings that form the name of the image
eval('img=imread(str);');
subplot(ceil(sqrt(M)),ceil(sqrt(M)),i)
imshow(img)
if i==3
title('Training set','fontsize',18)
end
drawnow;
[irow icol]=size(img); % get the number of rows (N1) and columns (N2)
temp=reshape(img',irow*icol,1); % creates a (N1*N2)x1 vector
S=[S temp]; % S is a N1*N2xM matrix after finishing the sequence
end
% Here we change the mean and std of all images. We normalize all images.
% This is done to reduce the error due to lighting conditions and background.
for i=1:size(S,2)
temp=double(S,i));
m=mean(temp);
st=std(temp);
S,i)=(temp-m)*ustd/st+um;
end
% show normalized images
figure(2);
for i=1:M
str=strcat(int2str(i),'.jpg');
img=reshape(S,i),icol,irow);
img=img';
eval('imwrite(img,str)');
imshow(img)
drawnow;
if i==3
title('Normalized Training Set','fontsize',18)
end
end
% mean image
m=mean(S,2); % obtains the mean of each row instead of each column
tmimg=uint8(m); % converts to unsigned 8-bit integer. Values range from 0 to 255
img=reshape(tmimg,icol,irow); % takes the N1*N2x1 vector and creates a N1xN2 matrix
img=img';
figure(3);
imshow(img);
title('Mean Image','fontsize',18)
% Change image for manipulation
dbx=[]; % A matrix
for i=1:M
temp=double(S,i));
dbx=[dbx temp];
end
%Covariance matrix C=A'A, L=AA'
A=dbx';
L=A*A';
% vv are the eigenvector for L
% dd are the eigenvalue for both L=dbx'*dbx and C=dbx*dbx';
[vv dd]=eig(L);
% Sort and eliminate those whose eigenvalue is zero
v=[];
d=[];
for i=1:size(vv,2)
if(dd(i,i)>1e-4)
v=[v vv,i)];
d=[d dd(i,i)];
end
end
%sort, will return an ascending sequence
[B index]=sort(d);
ind=zeros(size(index));
dtemp=zeros(size(index));
vtemp=zeros(size(v));
len=length(index);
for i=1:len
dtemp(i)=B(len+1-i);
ind(i)=len+1-index(i);
vtemp,ind(i))=v,i);
end
d=dtemp;
v=vtemp;
%Normalization of eigenvectors
for i=1:size(v,2) %access each column
kk=v,i);
temp=sqrt(sum(kk.^2));
v,i)=v,i)./temp;
end
%Eigenvectors of C matrix
u=[];
for i=1:size(v,2)
temp=sqrt(d(i));
u=[u (dbx*v,i))./temp];
end
for i=1:size(u,2)
kk=u,i);
u,i)=u,i)./temp;
end
% show eigenfaces
figure(4);
for i=1:size(u,2)
img=reshape(u,i),icol,irow);
img=img';
img=histeq(img,255);
imshow(img)
drawnow;
if i==3
title('Eigenfaces','fontsize',18)
end
end
% Find the weight of each face in the training set
omega = [];
for h=1:size(dbx,2)
WW=[];
for i=1:size(u,2)
t = u,i)';
WeightOfImage = dot(t,dbx,h)');
WW = [WW; WeightOfImage];
end
omega = [omega WW];
end
% Acquire new image
% Note: the input image must have a bmp or jpg extension.
% It should have the same size as the ones in your training set.
% It should be placed on your desktop
InputImage = input('Please enter the name of the image and its extension \n','s');
InputImage = imread(strcat('D:\Documents and Settings\sis26\Desktop\',InputImage));
figure(5)
subplot(1,2,1)
imshow(InputImage); colormap('gray');title('Input image','fontsize',18)
InImage=reshape(double(InputImage)',irow*icol,1);
temp=InImage;
me=mean(temp);
st=std(temp);
temp=(temp-me)*ustd/st+um;
NormImage = temp;
Difference = temp-m;
p = [];
aa=size(u,2);
for i = 1:aa
pare = dot(NormImage,u,i));
p = [p; pare];
end
ReshapedImage = m + u,1:aa)*p; %m is the mean image, u is the eigenvector
ReshapedImage = reshape(ReshapedImage,icol,irow);
ReshapedImage = ReshapedImage';
%show the reconstructed image.
subplot(1,2,2)
imagesc(ReshapedImage); colormap('gray');
title('Reconstructed image','fontsize',18)
InImWeight = [];
for i=1:size(u,2)
t = u,i)';
WeightOfInputImage = dot(t,Difference');
InImWeight = [InImWeight; WeightOfInputImage];
end
ll = 1:M;
figure(68)
subplot(1,2,1)
stem(ll,InImWeight)
title('Weight of Input Face','fontsize',14)
% Find Euclidean distance
e=[];
for i=1:size(omega,2)
q = omega,i);
DiffWeight = InImWeight-q;
mag = norm(DiffWeight);
e = [e mag];
end
kk = 1:size(e,2);
subplot(1,2,2)
stem(kk,e)
title('Eucledian distance of input image','fontsize',14)
MaximumValue=max(e) % maximum eucledian distance
MinimumValue=min(e) % minimum eucledian distance
Friend,
Thanks a lot.
I've used this type of algorithm. I want another algorithm.
Help me by giving another algorithm. I'll be greatful to u.
regards
sagar.
sea002bd@yahoo.com
