HELP: matlab code needed for DFE
completelyuseless
Junior Member level 1
dfe matlab code
hi all.
i am in need of matlab code that will simulate a DFE that uses RLS algorithm with
adaptive forgetting factor. this algorithm was proposed by Weilau Zhuang.
any help would be greatly appreciated.
I dont know to much about DFE but, if you have the final version of matlab (may be previous versions might also do have) it has a DFE object built in itself, where you can call RLS algorithm with forgetting factors and everything. Please check!!
Reactions: SA.AS
    SA.AS
i know what you are talking about. but the built in functions and other goodies in matlab and simulink are based on the normal RLS algorithm(variable forgetting factor). the algorithm i have to use is a modified RLS algorithm. the forgetting factor is no longer variable, it is adaptive. i dont think there are even any text books that discuss it.
but thanks for your sugesstion anyway.
