[HELP]Matlab 7+EPS+PDFlatex - bounding box problem
eirp
Advanced Member level 1
Phase center
matlab eps bounding box
Hi all!
I have strange problem with importing vector pictures from Matlab 7 to PDFLatex.
My workflow is as follows (worked in Matlab 6.x!)
1) export picture from matlab as .eps
1a) edit .eps and copy bounding box from file - like
%%BoundingBox:    87   262   507   578
2) make .pdf from .eps using acrobat distiller (PDFLatex can't import eps directly)
3) import .pdf into PDFlatex using copied bounding box parameters
\includegraphics[bb=87 262 507 578,scale=0.5]{blabla.pdf}
using bound.box from eps. now the imported pictures have bad position!!!
I used this method in Matlab 6 :roll:
Any simple idea?
Thanks..
pdflatex bounding box
is it the bounding box alone that has the problem or the whole contents of figure has shifted.
brmadhukar
matlab figure bounding box
brmadhukar
Hello
I've noticed the problem is that bounding box of Matlab's figure is very big, figure isn't cropped properly...
any solution?
