I think the Mozilla is already installed by default when I installed RH 8.0, because I can open html files. During my tries in these 3 days, I got the following result. If I left the Mozilla opened with any html file, not necessarily using those htmls from ldv/doc directory, next I start "nclaunch -new &" then I can click & open the nclaunch's HELP menu.galant said:If you wanna to open the LDV helps,you must install netscape.
At the very beginning when I tried to install it, I had had this problem also. Then I try to create an CDS_INST_DIR environment variable by using "export CDS_INST_DIR=<your_tared_directory>" in ~/.bashrc. This will solve this issue. But I don't know if my fix is correct or not. Regarding the complete package, I think we have to find out the BASE release. Who can help this ?Aigneryu said:I also encountered an error message
after I installed (in fact, just extract the tared file and make a link)
I saw an error message when I start nclaunch
The message says: Error: Unable to find an 'hdl.var' file to load in
What does it mean and how to fix it?
