Help in using LDR and ADC in 8051
victor_krum
Newbie level 1
Newbie level 1
Hi I need help on how to use LDR and ADC0804 in 8051 microcontroller.
So far I have this in my project but I want to replace the switch with LDR (dark activated).
What happens here (attached file)is that I use the switch to decrement/increment the number of cars and when it reaches to 0(no available space) the LCD will prompt that it is full.
What I want is using a sensor(ldr) and a laser light so that when a car passes (the light will be broken) the ldr will send signal and decrement the number of spaces and vice versa( i'll be using two ldr one for exit the other for entrance).
attached is my design. Im using Isis Proteus 7.4 and the code below
DB0 EQU P1.0
DB1 EQU P1.1
DB2 EQU P1.2
DB3 EQU P1.3
DB4 EQU P1.4
DB5 EQU P1.5
DB6 EQU P1.6
DB7 EQU P1.7
EN EQU P3.7
RS EQU P3.6
RW EQU P3.5
DATA EQU P1
;7-Segment Display
enableDIGIT3 EQU P3.2
enableDIGIT4 EQU P3.3
ZERO    EQU   10001000b
ONE     EQU   10111110b
TWO     EQU   11000100b
THREE   EQU   10010100b
FOUR    EQU   10110010b
FIVE    EQU   10010001b
SIX     EQU   10000001b
SEVEN   EQU   10111100b
EIGHT   EQU   10000000b
NINE    EQU   10010000b
DOT     EQU   01111111b
MOV 20h,#ZERO
MOV 21h,#ONE
MOV 22h,#TWO
MOV 23h,#THREE
MOV 24h,#FOUR
MOV 25h,#FIVE
MOV 26h,#SIX
MOV 27h,#SEVEN
MOV 28h,#EIGHT
MOV 29h,#NINE
MOV R0, #20h
MOV R1, #22h
PDATA EQU P2 ; Connect 8 pins here
CLR 51h
LCALL LCD_WELCOME
Start:
	JB P3.1, check1
		SETB 50h
	check1:
	JB P3.0, check2
		SETB 52h
	check2:
		JNB P3.1, cont1
			JNB 50h, cont1
				CLR 50h
				LCALL INC_7SEGMENT
	cont1:
		JNB P3.0, cont2
			JNB 52h, cont2
				CLR 52h
				LCALL DEC_7SEGMENT
	cont2:
		LCALL SHOW_7SEGMENT
		LCALL SHOW_LCD
SJMP Start
SHOW_LCD:
	CJNE @R0, #ZERO, welcome
	CJNE @R1, #ZERO, welcome
		JB 51h, done_showlcd
		LCALL LCD_FULL
	sjmp done_showlcd
	welcome:
		JNB 51h, done_showlcd
		LCALL LCD_WELCOME
	done_showlcd:
RET
LCD_FULL:
	LCALL CLEAR_LCD
	LCALL INIT_LCD
	CLR RS
	MOV DATA,#086H
	SETB EN
	CLR EN
	LCALL WAIT_LCD
	MOV A,#'F'
	LCALL WRITE_TEXT
	MOV A,#'U'
	LCALL WRITE_TEXT
	MOV A,#'L'
	LCALL WRITE_TEXT
	MOV A,#'L'
	LCALL WRITE_TEXT
	MOV A,#'!'
	LCALL WRITE_TEXT
	MOV A,#'!'
	LCALL WRITE_TEXT
	SETB 51h
RET
LCD_WELCOME:
	LCALL CLEAR_LCD
	LCALL INIT_LCD
	CLR RS
	MOV DATA,#081h
	SETB EN
	CLR EN
	LCALL WAIT_LCD
	MOV A,#'P'
	LCALL WRITE_TEXT
	MOV A,#'A'
	LCALL WRITE_TEXT
	MOV A,#'R'
	LCALL WRITE_TEXT
	MOV A,#'K'
	LCALL WRITE_TEXT
	MOV A,#'I'
	LCALL WRITE_TEXT
	MOV A,#'N'
	LCALL WRITE_TEXT
	MOV A,#'G'
	LCALL WRITE_TEXT
	MOV A,#' '
	LCALL WRITE_TEXT
	MOV A,#'S'
	LCALL WRITE_TEXT
	MOV A,#'P'
	LCALL WRITE_TEXT
	MOV A,#'A'
	LCALL WRITE_TEXT
	MOV A,#'C'
	LCALL WRITE_TEXT
	MOV A,#'E'
	LCALL WRITE_TEXT
	CLR RS
	MOV DATA,#0C3h
	SETB EN
	CLR EN
	LCALL WAIT_LCD
	MOV A,#'A'
	LCALL WRITE_TEXT
	MOV A,#'V'
	LCALL WRITE_TEXT
	MOV A,#'A'
	LCALL WRITE_TEXT
	MOV A,#'I'
	LCALL WRITE_TEXT
	MOV A,#'L'
	LCALL WRITE_TEXT
	MOV A,#'A'
	LCALL WRITE_TEXT
	MOV A,#'B'
	LCALL WRITE_TEXT
	MOV A,#'L'
	LCALL WRITE_TEXT
	MOV A,#'E'
	LCALL WRITE_TEXT
	CLR 51h
RET
INC_7SEGMENT:
	CJNE @R1, #TWO, increment
	sjmp doneinc
	increment:
		CJNE @R0, #NINE, incr0
		MOV R0, #20h
		INC R1
		SJMP doneinc
		incr0:
			INC R0
	doneinc:
RET
DEC_7SEGMENT:
	CJNE @R0, #ZERO, dec0
	CJNE @R1, #ZERO, dec1
	sjmp donedec
	dec1:
		MOV R0, #29h
		DEC R1
		SJMP donedec
	dec0:
		DEC R0
	donedec:
RET
SHOW_7SEGMENT:
	MOV PDATA,#00h
   	setb enableDIGIT3
   	MOV     A,@R1
   	MOV PDATA,A
   	LCALL smallDelay
	clr enableDIGIT3
   	setb enableDIGIT4
   	MOV     A,@R0
   	MOV PDATA,A
   	LCALL smallDelay
	clr enableDIGIT4
RET
INIT_LCD:
	CLR RS
	MOV DATA,#38h
	SETB EN
	CLR EN
	LCALL WAIT_LCD
	CLR RS
	MOV DATA,#0Ch
	SETB EN
	CLR EN
	LCALL WAIT_LCD
RET
CLEAR_LCD:
	CLR RS
	MOV DATA,#01h
	SETB EN
	CLR EN
	LCALL WAIT_LCD
RET
WRITE_TEXT:
	SETB RS
	MOV DATA,A
	SETB EN
	CLR EN
	LCALL WAIT_LCD
RET
WAIT_LCD:
	CLR EN ;Start LCD command
	CLR RS ;It's a command
	SETB RW ;It's a read command
	MOV DATA,#0FFh ;Set all pins to FF initially
	SETB EN ;Clock out command to LCD
	LCALL smallDelay
	MOV A,DATA ;Read the return value
	JB ACC.7,WAIT_LCD ;If bit 7 high, LCD still busy
	CLR EN ;Finish the command
	CLR RW ;Turn off RW for future commands
RET
smallDelay:
		CLR TF1
		CLR TR1
		MOV TH1,#76
		MOV TL1,#01
		MOV TMOD,#01
		SETB TR1
		JNB TF1,$
RET
