help in shaft or motor encoders
bhavikparekh51
Member level 1
Member level 1
mumbai
hello
I am working on a project in which i need to continuously measure a distance and then take a turn RIGHT or LEFT or stop at a particular point .....which type of encoders i can use ...?? absolute or incremental encoders............
hello
Either one. But for the same resolution, absolute encoders will be much more expensive. On the othe hand, incremental encoders require a zero resetting operation when started from an unknown position.
Please give me some tutorials on Quadrature/Incremental Encoder which could measure a distance by using arduino or any other microcontroller
Check if there are available some Arduino designs based on microcontrollers - such as pic30f6010 and lm3s6965 - which have built in circuitry proper for interface with incremental Encoder devices.
Can I use shaft encoders in case of non- wheeled bots or bots with crawling mechanism???
please reply as soon as possible...
Can U Suggest me some Shaft or Motor Encoder modules which is readily available .....
Help is needed urgent ..... please help me.....:D
