help in moving robots according to the coordinates provided
bhavikparekh51
Member level 1
Member level 1
mumbai
hello;
I am working on a project for moving a robot in a straight line with the co-ordinates (X,Y) provided by for start and end points.How should i go with it?? what components i would be needing???
please help me asap....... i am new to robotics....
Thank you...
What range?, what surface? what speed? any load? inside or outside? what technology? give us a clue!
Frank
Range about 30 meters and surface may be a play ground surface.It is outdoor application.Speed is a normal speed at which a bot works........We are going to use GPS Technology along with accelerometer............ could we use some other technology which has a better accuracy than GPS .....Plzz also give ur suggestions....
Thank You.....
