nbastar
chip: epm7128slc84-15
software: maxplus2
program: vhdl
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_arith.all;
USE ieee.std_logic_unsigned.all;
ENTITY golf00 IS
PORT (a1, a2,a3, a4,a5, a6,a7, a8,a9, a10,a11, a12,a13, a14,a15: IN std_ulogic;
a16,a17,a18,a19,a20,a21,a22, a23,a24, a25,a26, a27,a28, a29: IN std_ulogic;
a30,a31,a32,a33,a34,a35,a36,a37,a38,a39,a40,a41,a42,a43,a44,a45,a46,a47,a48: IN std_ulogic;
res, cp : IN std_ulogic;
q : OUT std_ulogic;
qa : OUT std_ulogic_vector(6 downto 0)
END golf00;
ARCHITECTURE RTL OF golf00 IS
signal temp1: std_ulogic_vector(9 downto 0);
signal temp2: std_ulogic_vector(9 downto 0);
signal temp3: std_ulogic_vector(9 downto 0);
signal temp4: std_ulogic_vector(9 downto 0);
signal temp5: std_ulogic_vector(9 downto 0);
signal temp6: std_ulogic_vector(9 downto 0);
signal temp7: std_ulogic_vector(9 downto 0);
signal temp8: std_ulogic_vector(3 downto 0);
signal temp9: std_ulogic_vector(3 downto 0);
signal temp10: std_ulogic_vector(2 downto 0);
signal y1,y6: std_logic;
signal y2,y5: std_logic;
signal y3,y4: std_logic;
BEGIN
y1<= a1 and a2 and a3 and a4 and a5 and a6 and a7 and a8 and a9;
y2<=a10 and a11 and a12 and a13 and a14 and a15 and a16 and a17 and a18 and a19;
y4<=a20 and a21 and a22 and a23 and a24 and a25 and a26 and a27 and a28 and a29;
y5<=a30 and a31 and a32 and a33 and a34 and a35 and a36 and a37 and a38 and a39;
y6<=a40 and a41 and a42 and a43 and a44 and a45 and a46 and a47 and a48;
y3<=y1 and y2 and y4 and y5 and y6;
TEMP1<=a9&a8&a7&a6&a5&a4&a3&a2&a1&'1';
TEMP2<=a19&a18&a17&a16&a15&a14&a13&a12&a11&a10;
TEMP3<=a29&a28&a27&a26&a25&a24&a23&a22&a21&a20;
TEMP4<=a39&a38&a37&a36&a35&a34&a33&a32&a31&a30;
TEMP6<='1'&a48&a47&a46&a45&a44&a43&a42&a41&a40;
TEMP9<=y6&y4&y3&y2;
PROCESS(Y3)
BEGIN
if(Y3'EVENT AND Y3='0') THEN
TEMP5<=temp1 and temp2 and temp3 and temp4 and temp6;
END IF;
END PROCESS;
qa(0)<=not(temp5(1) and temp5(3) and temp5(5) and temp5(7) and temp5(9) );
qa(1)<=not(temp5(2) and temp5(3) and temp5(6) and temp5(7) );
qa(2)<=not(temp5(4) and temp5(5) and temp5(6) and temp5(7) );
qa(3)<=not(temp5( 8 ) and temp5(9) ) ;
PROCESS(Y3)
BEGIN
case temp9 is
WHEN"0111"=>TEMP10<="100"; --40
WHEN"1011"=>TEMP10<="011"; --30
WHEN"1101"=>TEMP10<="010"; --20
WHEN"1110"=>TEMP10<="001"; --10
WHEN OTHERS=>TEMP10<="000";--00
END CASE;
END IF;
END PROCESS;
qa(4)<=TEMP10(0);
qa(5)<=TEMP10(1);
qa(6)<=TEMP10(2);
q<=y3;
END RTL;
output : it is wrong.
if i change the chip like flex6000(epf6010atc100), it is ok.
i want to use epm7128slc , why not?
plese help me!!
software: maxplus2
program: vhdl
LIBRARY ieee;
ENTITY golf00 IS
q : OUT std_ulogic;
END golf00;
BEGIN
TEMP9<=y6&y4&y3&y2;
PROCESS(Y3)
BEGIN
END IF;
END PROCESS;
PROCESS(Y3)
BEGIN
case temp9 is
END CASE;
END IF;
END PROCESS;
qa(4)<=TEMP10(0);
qa(5)<=TEMP10(1);
qa(6)<=TEMP10(2);
q<=y3;
END RTL;
plese help me!!
