Help in Linked list in VB
neoaspilet11
Full Member level 5
Full Member level 5
Cebu, Philippines
Hello,
How to remove and add an item in a linked list anywhere in the listl?
I just improve the deitel n deitel code for linked list and it works fine in manipulating at both ends (front and back ends) of teh linked list but no code is given if manipulating (inserting and deleting inside teh list).
Please help
Here's my improved deitel's and deitels code for VB linked list
'Class cListNode
' February 10, 2008
Option Explicit
Private mNodeData As Variant
Private mNextNode As cListNode
Public Property Get Data() As Variant
Set Data = mNodeData
End Property
Public Property Let Data(Data As Variant)
Set mNodeData = Data
End Property
Public Property Get NextNode() As cListNode
Set NextNode = mNextNode
End Property
Public Property Let NextNode(Data As Variant)
Set mNextNode = Data
End Property
' Class Clist
' February 12, 2008
Option Explicit
Private mFirstNode As cListNode
Private mLastNode As cListNode
Public Function IsEmpty() As Boolean
IsEmpty = IIf(mFirstNode Is Nothing, True, False)
End Function
Public Sub InsertAtFront(InsertItem As Variant)
Dim TempNode As cListNode
If IsEmpty() Then
Set mFirstNode = New cListNode
Set mLastNode = mFirstNode
Else
Set TempNode = mFirstNode
mFirstNode.NextNode = TempNode
End If
mFirstNode.Data = InsertItem
End Sub
Public Sub InsertAtBack(InsertItem As Variant)
If IsEmpty() Then
Set mLastNode = New cListNode
Set mFirstNode = mLastNode
Else
Set TempNode = mLastNode
TempNode.NextNode = mLastNode
End If
mLastNode.Data = InsertItem
End Sub
Public Function RemoveFromFront()
Dim RemoveItem As Variant
If IsEmpty() Then
RemoveFromFront = Null
Exit Function
End If
RemoveItem = mFirstNode.Data
If mFirstNode Is mLastNode Then
Set mFirstNode = Nothing
Set mLastNode = Nothing
Else
Set mFirstNode = mFirstNode.NextNode
End If
RemoveFromFront = RemoveItem
End Function
Public Function RemoveFromBack()
Dim Current As cListNode
If IsEmpty() Then
RemoveFromBack = Null
Exit Function
End If
RemoveItem = mLastNode.Data
Else
Set Current = mFirstNode
While Not Current.NextNode Is mLastNode
Set Current = Current.NextNode
Wend
Set mLastNode = Current
Set Current.NextNode = Nothing
End If
RemoveFromBack = RemoveItem
End Function
'This is my trouble and also inserting an item inside the list
Public Function RemoveFromList(ByVal ItemIndex As Integer)
Dim Elements As New cListIterator
Dim count As Integer
Dim Item As Variant
Dim CurrentNode As cListNode
' Process in removing an item from the list
' 1.) Iterate through the list, and count items until equal to ItemIndex
If IsEmpty() Then
Set RemoveFromList = Null
Exit Function
End If
Set Elements.StartNode = mFirstNode
count = 0
While Elements.HasMoreItems
Set CurrentNode = Elements.CurrentNode
Call Elements.ToNextNode
count = count + 1
If count = ItemIndex Then
Set RemoveItem = CurrentNode.Data
GoTo SHIFT_LIST
End If
Wend
If count < ItemIndex Then
Exit Function
End If
SHIFT_LIST:
CurrentNode.NextNode = Elements.CurrentNode
Wend
Set RemoveFromList = RemoveItem
End Function
Public Property Get Iterator() As Variant
Dim Iter As cListIterator
Set Iter = New cListIterator
Iter.StartNode = mFirstNode
Set Iterator = Iter
End Property
Public Property Get ItemsCount() As Integer
count = 0
count = count + 1
Wend
ItemsCount = count
End Property
'Class cListIterator
' February 12, 2008
Option Explicit
Private mBookMark As cListNode '
Private mFirstNode As cListNode ' Reference node
Public Property Let StartNode(Data As Variant)
Set mFirstNode = Data
Set mBookMark = mFirstNode
End Property
Public Sub ToNextNode()
If mBookMark Is Nothing Then
Exit Sub ' end of the list
Else
Set mBookMark = mBookMark.NextNode
End If
End Sub
Public Property Get CurrentNode() As cListNode
Set CurrentNode = mBookMark
End Property
Public Function HasMoreItems() As Boolean
HasMoreItems = IIf(Not mBookMark Is Nothing, True, False)
End Function
Public Sub ResetBookMark()
End Sub
