4tuty
Member level 3
I am using a costly photodetector FGA21 , it requires 3 volt reverse bias (absolute maximum).I am powering the device using smartphone (5V). I have 3.3 volt regulator which is exceeding the voltage rating shall i use voltage divider (10k&100k)? or shall i use voltage reference IC (2.8) 2.5v or 3 V. And, Do i need opamp transimpedence amplifier of simply connect the voltage output (PFA) to teensy 3.2 developer board advice needed.
Thank you
Thank you
