help in choosing the right components for energy harvesting application
jeromekang
Junior Member level 3
Philippines
hi im planning to create a energy harvesting circuit that will be directly connected to a 1.2V NiMH battery to charge it and measure the current going to the battery. I would like to hear your suggestions for components to optimize this setup especially the dc-dc converter
the setup im thinking of to test the idea of the battery charging with a piezo is
piezo -> rectifier -> dc-dc converter -> battery
is this the optimal setup to avoid losses?
Thanks
How much voltage from your piezo?
If you're talking about small piezo found in toys that makes sound, it's just to forget. There is almost no power at all.
when i tested it in an oscilloscope, i got around 10+v pk-pk. i don't think it's found in toys, more like in audio related applications
Can you post a picture of that?
How much current can you get out of it?
