[Help]How to use UART and M2Mpower IDE for GR47 Module
reflectarray
Member level 3
Member level 3
m2mpower ide
Hi, I'm doing my project using Sony Ericsson GR47 GSM/GPRS module. Firstly I'd like to learn how to use UART in GR47, especially UART 1 and UART3.
I've written simple program(scripts) using M2MpowerIDE to control UART3, but nothing happen at all.
I also checked UART3 pin(Tx and Rx) using oscilloscope but again ocsilloscope didn't show anything.
I've written same script as in M2Mpower Application Guide, but I still can't use it.
M2Mpower IDE connected via UART1 and I'm sure my hardware is no problem at all.
It can send and receive SMS which I made using M2MpowerIDE, but I couldn't monitor it using UART3.
Any helps would be greatly appreciated... thank in advance.
m2mpower application guide
Hello
I have a GR47 but no development board.
I would like to clean the script inside my module but i still dont know how to do it.
Any help?
I have read some of the aplication notes from sonyericson.
I try to connect the GR47 to uart2 and uart 1 with max3232 but nothing happens.
thanks
jaime
script gr47
For downloading or deleting script using M2Mpower IDE, you should connect GR47 via UART1. UART 2 for debug.
To do it with M2mpower IDE:
-Make sure your GR47 connection with M2mpower IDE works well.
-Press "Stop Running Embedded Scripts From StartUp"
-Also " Stop Running Embedded Script"
-And then "Delete Embedded Script"
It depends on where you save your scripts. GR47 is able to save up 2 scripts(in slot 0 and slot 1) at the same time, but you have to run only one script.
m2mpower ide torrent
do you have de sonyericson development board or have you done your own board?
    reflectarray
sony ericsson gr47 gprs module
No, I don't have dev.board for GR47. I don't use all GR47's functions so I think it's not necessary and it's quite pricey as well.
I use GR47 dev board myself.
What kind of project you want to make using GR47 ?
gr47 module
i would like to make a sms controller... nothing special.
Can i see you schematic of the development board?
i dont want to use the script of the GR47. I want to controll it by at commands. But o know that my gr was is own script and i want to clean it.
Added after 1 hours 1 minutes:
my gr was from a location system... it reads data from gps and send it over gprs...
if i could read the script maybe it help you...
I bought 3 Sony Ericsson GR47 GSM/GPRS module from e-bay but now I'm looking foar M2Mpower IDE. Can someone help me with this software?
thank you
