help:how to simulate CMRR and PSRR in Spectra
jacklee
Newbie level 2
Newbie level 2
hello guys......
i'm designning a opa in a BGR,how do i simulate CMRR and PSRR in spectra?
thank u!
Hello,
I think you should do the xf analysis. And when ploting your result, choose your diffirential input signal at first and the common mode input signal as second. Then you can use calculator to minus the above two curves (in dB). In this way you got the CMRR.
For PSRR, just replace the common mode source by the supply source. Do the same thing as said above.
Hope this can helps.
princerock
Reactions: merajece
    jacklee
    merajece
Robort,princerock,thank you!
