[SOLVED] help, how to make sound "coin in" like arcade games
Kfir Maymon
Member level 1
Member level 1
Israel
hi,
I'm building a box that recive coins and make something in return,.
my problem is that i don't know how to make the sound with electronic design.
i have electronic experience and i work with pic microcontroller.
i will appreciate if you give me ideas,
thanks guys
p. s
this is sounds that i want if it possible
https://youtu.be/CoMq9_qHjO8
hi,
You can buy this type of Record/Replay IC,
Or get an old style MP3 player and hack that into your project.
E
  • AudRec1.pdf
i will order one, but if you have more suggestions it will be great
hi,
thanks guys
p. s
Here is someone who is attempting the same thing
i solved it thanks,
i use pic to output 1000Hz for 0.08sec and after it 1333 for 0.8sec
and its the same sound.
now i need to learn hoe to work with speaker, its a new field for me.
this is what i connect
