Help! How to make open-drain in QuartusII 4 (Cyclone FPGA)?
mountain
Member level 2
Member level 2
cyclon 3 open drain
These is a system:
Altera Cyclone FPGA(3.3V) and a driver IC(5V)
I want to use the FPGA output as an open drain to get the low level and a pull-up for the high.
But how can I realize it in QuartusII 4.0(Altera)?
Please give me a sample code(Verilog-HDL or VHDL, but the Verilog-HDL is better). Thank you!
Re: Help! How to make open-drain in QuartusII 4 (Cyclone FPG
One way is like this:
output mysignal;
wire mysignal_int;
assign mysignal = (mysignal_int) ? 1'bz : 1'b0;
And then assign mysignal_int with any expression you like, and you don't have to worry about the open drain stuff in the rest of your code...
Thank you very much!
If you like, would you like to explain your method (or code)? I am a freshman.
Thank you!
Thank you!
If you use schematic capture see for OPNDRN primitive.
If you use AHDL - code example bellow:
SUBDESIGN open_drain
   in[3..0]   :INPUT;
   hiz[3..0]  :OUTPUT;
BEGIN
   FOR i IN 0 TO 3 GENERATE
       hiz[i] = OPNDRN(in[i]);
   END GENERATE;
