Help! How to install specman ?
egon
Member level 1
Member level 1
command not found1
hi,
when I launch the shell script, I get errors like command not found (not the script).
Is there anybody successfully has installed or has an install guide ?
Tia,
egon
shell script + : command not found1:
here is the error message, which i received, when i launch the install script.
[root@localhost setup_tmp]# sh ./install_specman4.1.sh
: command not found1.sh:
': not a valid identifierexport: `TMPDIR
'/install_specman4.1.sh: line 56: syntax error near unexpected token `{
'/install_specman4.1.sh: line 56: `check_env_path() {
package + specman
where can I download the Specman installation package?
whould you drop a link please (or let to know where to get it)?
