help how i can play wave file via modem (answer machine)
J_expoler2
Member level 4
Member level 4
HI
i programming VB to connected modem for ANSWER MACHINE using AT Command now it can detect ring and received calling but how i play wave file via modem and litent it via telephone
any one can help me pls.
Best regards
HI
I Programming In VB For Create ANSWER MACHINE With Mscomm using AT Command TOO .
Now How Can It Detect a Voice Or Fax Or Data was Received and After Connect How Can Play Wave For Message And Play Beep And Then Found What Button Was Pressed
Mohammad Ahmadi Zadeh From Iran-Tehran
Try openning your Voice Modem manual, it has several registers S1, S2, etc. You can get the value of the register (using AT Command) to check what button (DTMF) is pressed.
I still have the same problem with you (sending wav file through the modem).
I also tried to create a fax response server using VB, I can identify what button is pressed but I still cannot send the fax.
BS
