[SOLVED] [help]function call problem
romel_emperado
Advanced Member level 2
philippines
guys i need help ... How do i call the function mx_cal(); ?? what is that u8 line parameter? i dont have idea how do i call that from the function i made below which is burned_cal();
// system
#include "project.h"
// driver
#include "display.h"
#include "ports.h"
// logic
#include "romel.h"
#include "clock.h"
#include "date.h"
#include "user.h"
// Global Variable section
struct br mel;
s8 weight2, time;
s8 met2;
float kcal;
// Prototypes section
void display_romel(u8 line, u8 update)
if (update == DISPLAY_LINE_UPDATE_FULL)
display_chars(LCD_SEG_L2_5_0, (u8 *)" CAL0", SEG_ON);
void mx_cal(u8 line)
u8 select;
s32 weight;
s32 met;
// Clear display
clear_display_all();
// Convert global variables to local variables
//kcalories = mel.calories/1000;
met = mel.met_value/1000;
if (sys.flag.use_metric_units) weight = mel.user_weight;
else weight = ((s32)mel.user_weight * 2205) / 1000; // Convert kg to lb
// Init value index
select = 0;
// Loop values until all are set or user breaks set
while(1)
// Idle timeout : exit without saving
if (sys.flag.idle_timeout) break;
// Button STAR (short): save, then exit
if (button.flag.star)
// Store local variables in global structure
//mel.calories = kcalories*1000;
//mel.user_sex = sex;
mel.met_value = met*1000;
if (sys.flag.use_metric_units) mel.user_weight = weight;
else mel.user_weight = (weight * 1000) / 2205;
// Set display update flag
display.flag.line1_full_update = 1;
break;
switch (select)
case 0: // Set user weight
clear_line(LINE2);
display_chars(LCD_SEG_L2_1_0, (u8 *)"KG", SEG_ON);
set_value(&weight, 3, 2, USER_WEIGHT_MIN_KG, USER_WEIGHT_MAX_KG, SETVALUE_DISPLAY_VALUE + SETVALUE_NEXT_VALUE, LCD_SEG_L2_4_2, display_value1);
else
display_chars(LCD_SEG_L2_1_0, (u8 *)"LB", SEG_ON);
set_value(&weight, 3, 2, USER_WEIGHT_MIN_LB, USER_WEIGHT_MAX_LB, SETVALUE_DISPLAY_VALUE + SETVALUE_NEXT_VALUE, LCD_SEG_L2_4_2, display_value1);
weight2 = weight;
select = 1;
break;
case 1: //Set MET
display_chars(LCD_SEG_L2_1_0, (u8 *)"ME", SEG_ON);
set_value(&met, 3, 2, USER_WEIGHT_MIN, USER_METS_MAX, SETVALUE_DISPLAY_VALUE + SETVALUE_NEXT_VALUE, LCD_SEG_L2_4_2, display_value1);
met2 = met;
select = 0;
break;
// Clear button flags
button.all_flags = 0;
//calorie expernditure forMULa
void burned_cal(void)
if(sTime.second == 60)
time++;
kcal = ((met2 * 3.5 * (weight2/2.2)) / 200) * time;
In mx_cal(), I didn't see the parameter 'line' being used at all. So, u can supply any value when call it.
e.g. just call mx_cal(5) will do in your routine.
Regards,
Tom
yes that is my problem i didnt see the parameter.. i dont know where that u8 line from..
does it perform if i put any value?? thanks
another question.. as what u can see in my burned_cal function is it possible to get the value of weight2 and met2 from the mx_cal() function above?
I have a quick look,
Ya, u can put any value when call mx_cal. The value is simply not used in the function.
mx_cal() contain an infinite loop which will exit only when idle timeout and Button STAR. So, it will get stuck inside until any of the two condition is meet. As the weight2 and met2 are global variable, they will be updated by any functions that access them, so it is able to be updated by mx_cal() function. I would advice you to initialize them to NULL first, incase mx_call() has not updated them and get exit after power-on.
Regards,
Tom
thanks tom...... :) thanks very much... :D
how about if i'll do declare like this in the separate *.h file
struct br
// User settings
u16 user_weight;
u32 calories;
u16 met_value;
u8 mode;
u8 met2;
u8 weight2;
u8 duration;
extern struct br mel;
and then use like this in a function.. does mx_cal(); function can still update the variables namely duration and met2??
if(mel.mode == 1)
mel.duration++;
mx_cal(2);
kcal = ((mel.met2 * 3.5 * (mel.weight2/2.2)) / 200) * mel.duration;
