poweric
Member level 5
hi i have burn in a AC-DC IC (integrate the MOSfet ), while working in the high temperature for 12 hours, the resistance between the drain and source of MOSFET become 5M, the the resistance between the source drain and sourec of MOSFET become 300K, the ininal values for these are infinite and 11M, then it canbe work.
after that the above IC is place in the hotroom (temp=175) for 4 hours not work condicitons , The Resistance between the drain-source and source-drain become the infinite and 11M , then it can work now.
we also find if IC is place in the hotroom for 4 hours first , then working in the high temprature for 12 hours , the resistance dont change any.
thank you for help
thank you for help
