MARWEN007
Junior Member level 2
Hi, I calculated the phase shift between two sine (50 Hz) and displayed on an LCD, I compile my prog on picc the problem is I can not calculate the phase shift for low frequency (0.05 Hz) had good results by cons for 50 Hz are obtained false values of phase shift here is my source code and the diagram on isis
#include <16f877.h>
#device ADC=10
#fuses xt,nowdt,NOPROTECT,noput
#use delay(clock=20000000)
#use rs232(baud=9600, xmit=PIN_C6,rcv=PIN_C7)
#include <lcd.c>
#include <math.h>
int32 n=0;
#int_timer0
void timer0_isr()
n++;
void main ()
int1 test_1, test_2;
//***********programme de dephasage******************//
//float a,b,c,e,f,g,R,X;
//float tens_max,courant_max,dephasage,Veff,Ieff ;
float temps, dephasage;
float tens_****_10,tens_****_1,tens_num_1,tens_num_2,tens_****_2,tens_****_20;
int8 Iter;
float Freq=10;
tens_****_10 = 0.1;
tens_****_20 = 0.1;
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
enable_interrupts(int_timer0);
enable_interrupts(GLOBAL);
disable_interrupts(int_timer0);
clear_interrupt(int_timer0);
setup_port_A(all_analog);
setup_adc(adc_clock_internal);
while(true)
while(!input(pin_C0))
test_1=1;
test_2=1;
set_adc_channel(0);
delay_us(10);
while(test_1==1)
tens_num_1 =read_adc();
tens_****_1 = (tens_num_1 *(0.0048876)*2)-5;
lcd_init();
printf(lcd_putc,"Tens1=%2.5f\r",tens_****_1);
//printf("T1=%2.3f\r",tens_****_1);
if ((tens_****_1>=0) && (tens_****_10<0))
set_timer0(0);
n=0;
test_1=0;
tens_****_10=tens_****_1;
//lcd_init();
//printf(lcd_putc,"Tens1=%2.5f\r",tens_****_1);
printf("Detected Tens1=%2.5f\r",tens_****_1);
else
tens_****_10 = tens_****_1;
set_adc_channel(1);
delay_us (10);
while (test_2==1)
tens_num_2=read_adc();
tens_****_2 = (tens_num_2 *(0.0048876))-2;
lcd_init();
printf(lcd_putc,"Tens2=%2.5f\r",tens_****_2);
//printf("T2=%2.3f\r",tens_****_2);
if ((tens_****_2>=0) && (tens_****_20<0))
Iter=get_timer0();
temps = 0.0000512*n+Iter*0.0000002;
dephasage =2*PI-((2*PI*Freq)*temps);
test_2=0;
tens_****_20=tens_****_2;
//lcd_init();
//printf(lcd_putc,"Tens2=%2.5f\r",tens_****_2);
printf("Detected Tens2=%2.5f\r",tens_****_2);
printf("temps=%3.5f\r",temps);
else
lcd_init();
printf(lcd_putc,"Deph=%3.5f deg\r",dephasage*57.295779513);
printf("Deph=%3.5f deg\r",dephasage*57.295779513);
the isis diagram https://obrazki.elektroda.pl/8_1303829582.png
#include <16f877.h>
#device ADC=10
#include <lcd.c>
#include <math.h>
int32 n=0;
#int_timer0
void timer0_isr()
n++;
void main ()
int8 Iter;
float Freq=10;
tens_****_10 = 0.1;
tens_****_20 = 0.1;
while(true)
test_1=1;
test_2=1;
set_adc_channel(0);
delay_us(10);
while(test_1==1)
lcd_init();
set_timer0(0);
n=0;
test_1=0;
//lcd_init();
else
set_adc_channel(1);
delay_us (10);
while (test_2==1)
lcd_init();
Iter=get_timer0();
test_2=0;
//lcd_init();
else
lcd_init();
