kg300
Member level 3
- Joined
- Sep 21, 2007
- Messages
- 67
- Helped
- 62
- Reputation
- 124
- Reaction score
- 68
- Trophy points
- 1,308
- Location
- RY Khan - PAK
- Activity points
- 1,853
Hi Friends, I need some help for winding a transformer. I have a 12VDC to 220VAC Inverter, in which EI40 Ferrite core Transformer is used with following specifications,
Pri turns #4-0-4 (center tape)
Sec turns #72
Input volt #12V
Output Volt #300V
Switch Frequency #50khz
Output current #4amp
Now if I use EI42 core in it with same Input and Output ratings, what number of turn on Pri and Sec will be wound?
Thanx
Sec turns #72
Input volt #12V
Output Volt #300V
Thanx
