Help for Current to voltage converter
fasto2008
Member level 4
Member level 4
Usa
current to voltage converter
Hi all.. I'm designing an application in technology TSMC 0.18µ.
The last block is a current to voltage converter.
All circuits Current to voltage converter, i used give me a voltage 500mV
But i need a current-voltage converter to have a higher voltage to 1.3V from current 400µ.
Thanks a lot for help
current voltage converter
...so attach a simple voltage amplifier with the gain about 2.5V/V.
current to voltage converter using transistor
only 1.3 voltage from 400uA? If so, it's simple question. I think it is not . write other restrictions, the answer is meaningful.
convert current to voltage
Hello antonio_eda,
you sad :a simple voltage amplifier with the gain about 2.5V/V.
Is there a schematic ampllifier using transistor NMOS and PMOS
Thank you in advance for your help
schematic current to voltage converter
maybe you can only use a I/V signal amplifier module directly,such as:0-20mA to 0-10V
Hallo,
Can you write the problem more clearly,
What i understood was, you want to convert current into voltage.. right??
USe transimpedance amplifier with high feedback resistance which give trnsimpedance gain.
i hope you understood what i mean
Thanks
current-to-voltage converter high current
I just want a simple design of current to voltage converter by CMOS
thanks a lot
Hello
Really i'm so happy for help given from everyone, but i will explain problem more clearly after somes modifications:
i just want a simple current to voltage converter using transistors NMOS and PMOS .
So the current (Iin) between -100u and 100u.
and the voltage (Vout) between 0 and 1.3V.
Thanks in advance for help
fasto
