s3034585
Full Member level 4
Hi
I am using Cadence Virtuoso XL for layout design.. When i am trying to design a layout with multiple blocks, i am facing a lot of problems while making the interconnections. While connecting the blocks many a times the block gets selected and gets moved from its place. So is there any way by which i can freeze the locations of the block so that they dont move and i can make the connections without have a tension of the blocks getting moved.
Does cadence virtuoso xl have any such command of option in it .
eg a layout of 16 * 16 matrix of a latch. as it will have 256 latchs, so while making their connections i want to freeze the location of the blocks so that they wont move.
If anyone is having some info on this kindly let me know.
Thanks in advance.
Thanks in advance.
