[SOLVED] Help for Assembler 12F675
MAS4585
Newbie level 5
Newbie level 5
Hello All
Good Evening...
I am trying to design a Fish feeder timer with 12F675. Its has 5 Pre Programmed out put that are for 1 Second,2 ,4,6 and 8 seconds.
Output will turn off after the pre programed time was reached. Simulation of the circuit with Proteus is working... But the real hardware showing some faulty trigger.
when I complile the code with MPlab 8.33, There show an error.
"Symbol not previously defined (TMR0IE)"
Please see the complete code below.
 list n=0, c=150, r=dec
; File: main.asm
; Target: PIC12F675
;                          ___ ___
;                   VDD ->|1  U  8|<- VSS
;                  LED1 <>|2     7|<> LED3
;                  LED2 <>|3     6|<> LED4
;                  SW1n ->|4     5|<> LED5
;                         PIC12F675
;  If the switch is Press and hold (My timer output is enable for 1 Minute minimum) either Press, all LED will be ON.
;  After 1 Second, LED 1 Turn Off,
;  After 2 Second, LED 2 Turn Off
;  After 4 Second, LED 3 Turn Off
;  After 6 Second, LED 4 Turn Off
;  After 8 Second, LED 5 Turn Off.
;  (5 LED is used for Manual Timer selection for the Motor will Enable..)
#include <p12f675.inc>
	LIST
;  MPASM PIC12F675 processor include
;  (c) Copyright 1999-2013 Microchip Technology, All rights reserved
	LIST
	errorlevel -302         ; suppress banksel warning	messages
	__CONFIG _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON	&	_MCLRE_OFF & _BODEN_ON & _CP_OFF & _CPD_OFF
#define TIMER0_INTERRUPTS_PER_SECOND D'4000'
#define LED1 GPIO,5
#define LED2 GPIO,4
#define LED3 GPIO,0
#define LED4 GPIO,2
#define LED5 GPIO,1
#define SW1n GPIO,3
ISR_DATA    udata_shr  0x20
WREG_save       res 1
STATUS_save     res 1
TIMER_DATA  udata_shr
IntsInOneSecond res 2
Seconds         res 1
RESET_CODE  CODE 0x000
	goto    Start
ISR_CODE    CODE 0x004
	movwf   WREG_save
	movf    STATUS,W
	movwf   STATUS_save
	btfsc   INTCON,TMR0IE
	btfss   INTCON,TMR0IF
	goto    ISR_Exit
	bcf     INTCON,TMR0IF
	movlw   256-250+3
	addwf   TMR0,F
	movlw   -1
	addwf   IntsInOneSecond,F
	skpc
	addwf   IntsInOneSecond+1,F
	skpnc
	goto    ISR_Exit
	movlw   HIGH(TIMER0_INTERRUPTS_PER_SECOND-1)
	movwf   IntsInOneSecond+1
	movlw   LOW(TIMER0_INTERRUPTS_PER_SECOND-1)
	incf    Seconds,F
ISR_Exit:
	movf    STATUS_save,W
	movwf   STATUS
	swapf   WREG_save,F
	swapf   WREG_save,W
	retfie
START_CODE  CODE
Start:
	btfsc   STATUS,RP0
	goto    OscillatorCalibrationFailed
	banksel OSCCAL
	call    GetOSCCAL
	movwf   OSCCAL
OscillatorCalibrationFailed:
	banksel ANSEL
	clrf    ANSEL
	clrf    TRISIO
	movlw   B'11011111'
	movwf   OPTION_REG
	banksel INTCON
	clrf    INTCON
	clrf    GPIO
	movlw   0x07
	movwf   CMCON
	clrf    Seconds
	clrf    TMR0
	movlw   256-250+3
	addwf   TMR0,F
	bsf     INTCON,TMR0IE
	bsf     INTCON,GIE
AppStart:
	clrf    GPIO
AppLoop:
	btfsc   SW1n
	goto    AppLoop
	bcf     INTCON,TMR0IE
	clrf    Seconds
	movlw   B'00110111' ; LED1-5 on
	movwf   GPIO
	bsf     INTCON,TMR0IE
AppTimeout:
	movf    Seconds,W
	xorlw   D'1'
	skpnz
	goto    LED1_off
	xorlw   D'1'^D'2'
	skpnz
	goto    LED2_off
	xorlw   D'2'^D'4'
	skpnz
	goto    LED3_off
	xorlw   D'4'^D'6'
	skpnz
	goto    LED4_off
	xorlw   D'6'^D'8'
	skpnz
	goto    LED5_off
	xorlw   D'8'
	sublw   D'8'
	skpc
	goto    WaitForButtonUp
CheckSwitch:
	btfsc   SW1n
	goto    AppStart
	goto    AppTimeout
WaitForButtonUp:
	btfsc   SW1n
	goto    AppStart
LED1_off:
	movlw   B'00010111' ; LED1   off
	movwf   GPIO
	goto    CheckSwitch
LED2_off:
	movlw   B'00000111' ; LED1-2 off
	movwf   GPIO
	goto    CheckSwitch
LED3_off:
	movlw   B'00000110' ; LED1-3 off
	movwf   GPIO
	goto    CheckSwitch
LED4_off:
	movlw   B'00000010' ; LED1-4 off
	movwf   GPIO
	goto    CheckSwitch
LED5_off:
	movlw   B'00000000' ; LED1-5 off
	movwf   GPIO
	goto    CheckSwitch
OSCCAL_CODE CODE 0x3ff
GetOSCCAL:
	end
I dont understand, What is real problem....Any help would appriciated.
Regards
Try using "T0IE" instead, that is the name used on the data sheet.
Brian.
Yes...Its working....and compiling done with 0 % error.
But the simulation, in proteus, There is a warning message...
"Effect of writing OSCCAL register not modelled"....
How is it possible?
Regards...
I have just checked the include file P12F675.INC and TMR0IE is correct, you could just use the value 5 instead. The normal mistake that everyone makes is to use a o instead of an 0 in the name.
Sounds self-explanatory to me. It's Proteus.
Hi Fvm..
Greetings...
How to overcome the message "Effect of writing OSCCAL register not modelled" ?
and the circuit tested in real hardware, There is some unwanted triggering occured ...... sometimes its working good... but aftersome time all LEDs are blinking...
why this happen?
Regards
this is the video for the real hardware work...
https://youtu.be/kuD_LctpKAo
The message is just a warning about the simulation, it doesn't mean there is a problem with the code.
The OSCCAL register applies a small offset to the internal oscillator calibration but the exact amount it shift the frequency is not well defined. The main calibration is done in the factory with the OSCCAL being left to the user for 'fine tuning' if needed. Obviously a simulation can't tell how much adjustment, if any is needed.
Something else is causing your unwanted triggering, my first suspicion would be interference from the motor. Do you have good decoupling on the PIC supply pins and sufficient current isolation between the motor supply and PIC supply?
Brian.
Brian.
Its just my Idea only and not the motor to connect the circuit. I use LED in the output for testing the output.
Now OSCCAL register problem cleared. Think the circuit work well now in another PCB. 1K resistor are used in series with the output of the 12F675.
Updated circuit are here
How can use a potentiometer insted of various LED for time setting....?
Regards
That PIC has a built-in ADC so if you can spare the input pin, wire the potentiometer across VSS and VDD with the wiper going to the ADC input. Then use the ADC module to read the voltage (the ADC register value will suffice, there is no need to convert it to Volts) and use that value to pre-load the timer.
As you change the potentiometer setting you make the timer delay change.
Brian.
