nikhilsigma
Full Member level 2
- Joined
- Jun 19, 2010
- Messages
- 142
- Helped
- 17
- Reputation
- 34
- Reaction score
- 16
- Trophy points
- 1,298
- Location
- Delhi, India
- Activity points
- 2,584
Hey Guys....
Can i Program the ATmega 8 (with Firmware) with an USBasp.....??
as my friend have an USBasp, he got that in a workshop...
and if yes, then for that what i have to do....??
CLKOPT = 0
SUT1 = 1
SUT0 = 1
CKSEL(3,2,1,0) = 1,1,1,1
...yes nikhil, you can do that...and you've got all the pins right...
Source Pins >------> Target Pins (The ATmega8 you wish to program)
+5V >------> Pin 7
Gnd >------> Pin 8
MISO >------> Pin 18
MOSI >------> Pin 17
SCK >------> Pin 19
Reset >------> Pin 1
Put a 4Mhz/ 12 Mhz crystal between pins 9, 10 on the target and attach a 15pf ceramic cap with each leg of it, going to the ground and it's all set. And don't worry about the fuses if you are using ExtremeBurner or ProgISP softwares to write your chip; as my experience goes.
...happy burning...(I've prepared an attachment to program 28 and 40 pin AVR with USBasp, will soon publish that with my article, as some photographs have to be clicked :-D)
