help finding in catalog wider version of PTTC-704
yefj
Advanced Member level 5
Hello,I have this soldering tip PTTC-704 shown in the photos and link below. which is like twizers that i remove the shown below but its not wide enough.
I need to soldering tip to match the "solder handle" that PTTC-704 was sitting on.
How do i look in mouser catalog for soldering tip which fits the same "soldeing handle" but the tip is wider (so i could remove chips which bigger number of legs)
Thanks.
https://eu.mouser.com/ProductDetail...T*MTcxNjI2OTI5Ni4xLjEuMTcxNjI2OTQ0Mi41Ny4wLjA.
simply check the website from METCAL, ther I found 31 tips which are wider than 6.35 mm (0.25" - PTTC-704). Which one is suitable for your solder-tweezer handle I do not know, as you have not mentioned, altough I assume the MX series. There are still 10 tips (wider than 6.35 mm) listed for the MX series.
BR
LaTeX Commands Quick-Menu:
