Nmbr6
Newbie level 2
Hi all,
First post here, please be gentle...
I got this PCB in a casing I'm designing with 12 connections that need to go to the components that are on top of the casing.
I want to have a header on the PCB, and have all the components connected using a socket.
Problem is, the whole thing, connected, needs to be able to "hide" inside the casing and I don't have much room.
I also considered putting a right angle header next to the PCB and wire to it to save some space in Y.
Still, no matter how much I look, I can't find anything that would fit (I'm in the UK and usually order from rs components of farnell...)
Was wondering if anyone could point me in the right direction, or give me some alternative solution....
I attached two sketches of the possible ideas I had in mind with measurements (the PCB has 12, one line wholes with ~2.5 pitch)
Thanks!
Thanks!
