Help!ez430rf2500-seh solar energy tool-can not use UART mode
bettyxyz1028
Newbie level 6
Newbie level 6
I hav the ez430-rf2500-seh solar energy harvesting tool. I decided to make some modification based on the Demo code.
I wanna choose P3.5 (UART) as a receive pin.
I follow the sample codes to write a simple interrupt.
I disable the previous P3.5 function (connect to solar panel inner battery ) in the demo code.
I hav alrdy reserve a location in the msg. And the preset number can be transmitted out successfully.
I also use an echo (UCA0TXBUF=UCA0RXBUF) to test whether the ED receive the data from another board successfully.
Here comes the problem:
If i wanna the transmission btwn ED and AP, I cannt use P3SEL=0x20.
If i wanna the interrupt to happen, I hav to write in P3SEL=0x20.
I change the P3SEL=0x2F according to datasheet. But it can not work!
The cc2500 and MSP430f2274 communicate via SPI mode rite? Does that mean i can not use UART mode?
What exactly should i do to juz transfer an integer from another board to ez430-rf2500 target board????
Anybody can help me with this issue????? It looks like an easy task......
Thanks so much in advance!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Re: Help!ez430rf2500-seh solar energy tool-can not use UART
Here is my code:
linkTo()
P3SEL = 0x3f; // If i put this one here, transmission will fail
BCSCTL1 = CALBC1_1MHZ; // Set DCO = 1MHz
DCOCTL = CALDCO_1MHZ;
UCA0CTL1 |= UCSSEL_2; // SMCLK
UCA0BR0 = 0x68; // 1MHz 9600
UCA0BR1 = 0; // 1MHz 9600
UCA0MCTL = UCBRF_0 + UCBRS_1 ; // Modulation UCBRSx = 1
UCA0CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
IE2 |= UCA0RXIE; // Enable USCI_A0 RX interrupt
__enable_interrupt();
#pragma vector=USCIAB0RX_VECTOR
__interrupt void USCI0RX_ISR(void)
aNumber = UCA0RXBUF; // TX -> RXed character
IE2&=~UCA0RXIE;
Added after 53 seconds:
Another way:
UCA0CTL1 |= UCSWRST; //set the USCWRST
P3SEL |= 0x3f;//configure ports
UCA0CTL1 &= ~UCSWRST;//clear uscwrst
if(IFG2 & UCA0RXIFG)
else
aNumber=11;
Both can not work... Anyone can help??? tks
