help! error reported when P&R with SE of IC5 for linux
lcking
Member level 1
Member level 1
When I place instance with SE of IC5 for linux, the system report that " *ERROR* PR Engine process reports: /tmp/gcib29948.sh: sedsm: command not found ". How can I fix this problem?
don't use the function!
because you don't install se on your linux box and there is no linux version of se.
