mbider
Newbie level 6
elektronikon
Hello
I'm making the maintenance of a number of pressure regulators for atlas copco compressor.
The model of the regulator is:
ATLAS COPCO_MODEL: 1900-0701-24
On the front is marked ELEKTRONIKON
This model has, among other memory zero power timer 48T02 type and unfortunately it fails even if we put a new one it does not work because it needs a setup, I could solve the problem by copying the contents from one to another, but to change some parameters such as maximum pressure is impossible.
I would like to know if there is a way to set these values or a little of technical documentation.
Atlas copco no longer provides maintenance for these models there.
And thank you in advance
Hello
