The best thing to do is to replace R8 with a tuned circuit. If your aerial is 300/ 4 X F m. long then its a good aerial ( 9m), if the aerial is shorter then it needs an inductor in series with it to tune it and the aerial should be connected to a tap on the new tuned circuit (~ 10 % away from the Vdd end). So now you have two additional tuned circuits, both of which reduce the harmonic output and increase the output.
Frank
Here is what I see:
5.) analong input controls the Q3 transistor
6.) The analog signal is mixed into the reasonating carrier signal
7.) Resonating carrier signal is amplitude controlled with mixed analog input signal
i found like that for mixerThis thing is not a very good transmitter, it will have poor modulation linearity and needs an output filter to ensure the RF harmonics are sufficiently attenuated, the common base 'power' (maybe 10dBm or so ?) stage is kind of interesting howevr.
Regards, Dan.
orVdd*10k/20k - 10k//10k* Ib - Vbe - Ie* 1k = 0
Ic = Is * ( e^Vbe/Vt - 1)
