help: Design compiler error
dreamscome
Junior Member level 2
When I run dc_shell on RT9.
It said:
"Incorrectly built binary which accesses errno or h_errno directly. Needs to be fixed."
What did it mean?
Thanks!
RH9 is not compatible with DC. You should use RH7.2.
But how to let RT9 support DC?
export LD_ASSUME_KERNEL=2.4.1
although you can finally run dc on rh9, it is strongly recommended that you go back to rh7.3 because it will yield more reliable result.
