vineesh.1
I intend to make a project on an embedded system.
I shall be using a thermal printer, handheld bar code scanners with USB interface and a basic kaypad. I need help in deciding wat system do I use as a base. I cud do the proj using a comp, but the system needs to be compact. So shud I go in for a cpld or an fpga or sm microcontroller?
I'd be grateful to u for ur help.
Thnx in advance.
Thnx in advance.
