waosai
Member level 2
real signal vs complex signal
Hello everybody, I have some questions about signal type setting in simulink:
(1)“Real” and “complex”, which type should I use? What’s the difference between them?
(2)If I set the signal type to “complex”, whether I should add a “complex to magnitude-angle” module to see the output spectrum?
The detailed descripsion and figures are given in the attached word file.
