powersys
Advanced Member level 1
Copied from Control Systems Engineering (Nise/2ed/pg298):
1) What does the highlighted part mean?
2) Would u pls give examples of polynomial for the cases (between positive and negative, or imaginary axis roots) above?
Thanks
My questions:First, if the closed-loop transfer function has only left-half-plane poles, then the factors of the denominator of the closed-loop system transfer function consist of products of terms such as (s+ai), where ai is real and positive, or complex with a positive real part. The product of such terms is a polynomial with all positive coefficients. No term (coefficient) of the polynomial can be missing, since that would imply cancellation between positive and negative coefficients or imaginary axis roots in the factors...
Thanks
