ym2kmobile
Newbie level 3
I just recieve a project that required me to do ac/dc switching. The ac will be 230v, 50hz to power a application. When the ac power fail, a circuit from dc will pump in 12vdc to the application. There is 2 application connected thru the same ac and dc wiring (2 wire, AC/DC & GND), output (3 wire, AC, DC & GND). But the circuit i am going to design will switch to the ac application once the circuit detect ac and switch to the dc application once the circuit detect dc. I am trying to use a relay, but the problem is thats the switching time for a relay is not fast enough. The dc application cannot take in high voltage and high current from the mains and will blow in nano seconds when the mains power go in. Any recommendation to the circuit that will protect the dc application and will do a fast switching once it detect a change of power input(ac or dc).
Thanks, any help will be appreicated!
