Analogworld
Member level 1
Someone has posted this topic before, but no one ever provided a solution to solve this issue. I am now having the same situation that Spectre can not find the transistor model in the correctly pointed tsmcrf library. I am sure that the require Spectre model file is correctly pointed, and it works fine for the other devices (i.e. well or poly resistors) in the same file location.
Did anyone exprience this problem before? Please help
Spectre error message :
Command line:
/Cadence/IC5033/tools.lnx86/spectre/bin/spectre -env artist5.0.0 \
+escchars +log ../psf/spectre.out +inter=mpsc \
+mpssession=spectre0_3023_3 -format psfbin -raw ../psf \
input.scs
spectre pid = 3618
Loading /Cadence/IC5033/tools.lnx86/spectre/lib/cmi/3.0/libinfineon_sh.so ...
Loading /Cadence/IC5033/tools.lnx86/spectre/lib/cmi/3.0/libnortel_sh.so ...
Loading /Cadence/IC5033/tools.lnx86/spectre/lib/cmi/3.0/libphilips_sh.so ...
Loading /Cadence/IC5033/tools.lnx86/spectre/lib/cmi/3.0/libstmodels_sh.so ...
spectre (ver. 5.0.33.031705 -- 17 Mar 2005).
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA
Security, Inc.
Simulating `input.scs'
Compiling ahdlcmi module library.
Finished compilation in 1 s (elapsed).
Installed compiled interface for bsource_1.
Installed compiled interface for bsource_2.
Installed compiled interface for bsource_3.
Installed compiled interface for bsource_5.
Installed compiled interface for bsource_41.
Installed compiled interface for bsource_42.
Installed compiled interface for bsource_56.
Installed compiled interface for bsource_68.
Installed compiled interface for bsource_69.
Installed compiled interface for bsource_83.
Installed compiled interface for bsource_85.
Installed compiled interface for bsource_90.
Installed compiled interface for bsource_101.
Error found by spectre during circuit read-in.
input.scs: M0 is an instance of an undefined model nmos2v.
spectre terminated prematurely due to fatal error
Command line:
input.scs
spectre pid = 3618
Security, Inc.
