zhangjavier
What does the following notices mean when using Analog design envoriment to simulate a circuit??
Only one conntection to the folowoing nodes....
No dc path from node...to ground.
These notices appeared when I simulated the circuit after parasictic extractred. In fact there were no such notices when I just simulated the schematic. The shematic and the layout mathed.
I don't why. How could the parasitic elements change the circuit so much that even block the dc path??
And I also want to know how to find some node or parasitic element in the layout by knowing its name??
Thank you so much~!!
