easygoing
Junior Member level 1
OS: Redhat 9.0 and Redhat 7.2(I try them n times).
After I setup the total software and run it , error shows below:
"8-bit Pseudocolor visual is not available(default visual option )
using 24-bit truecolor visual.The program xdpyinfo can be used to verify the visual available for your display."
And then I change the defaultDepth Para of XF86CONFIG-4 file from 24 to 8,above error is disappear and the color become bad.
But show another error:
"Use/reproduction/disclosure is subject to restriction set forth at FAR 1252.227-19 or its equivalent
Program(#)$CDS:icfb.exe version 5.0.0.01/01/2003 19:46(intelibm1) $
Sub version: sub-version 5.5.5.500.28(32-bit addresses)"
I have tried the setup (redhat 7.2&9.0) for n times.and I have studied the install guides from the forum and other forum. But I still can't setup it successfully.
Anyone can help me ?Thank you very much
Best Regards
easygoing
Best Regards
easygoing
