Help Assembly code PIC16F877A ultrasonic project
jian999
Newbie level 3
Newbie level 3
Read distance in the 16x2 LCD using hc-sr04 ultrasonic and pic16f877a........I found lots of information but not used because all are in c language..................pls someone can give me assembly code for this project (I stuck in calculation and display )
How abut showing what you have done so far as a start?
John
HTML:
LIST P=16F877A
#INCLUDE <P16F877A.INC>
__CONFIG   0X3F32
; MACRO
BANK0        MACRO                    ;CHANGE TO BANK 0
            BCF        STATUS,RP0
            BCF        STATUS,RP1
            ENDM
BANK1        MACRO                    ;CHANGE TO BANK 1
            BSF        STATUS,RP0
            BCF        STATUS,RP1
            ENDM
CLOCK_E        MACRO                    ;'E' RISE UP N FALL DOWN
            BSF        PORTB,7
            CALL    DELAY1
            BCF        PORTB,7
            CALL    DELAY1
            ENDM
; RESET VECTOR
            ORG        00h
RESET        GOTO    INIT
;INTERRUPT VECTOR
            ORG        04h
            RETFIE
; INITIALIAZATION OF I/O
            ORG        05h
INIT    BANK1
        CLRF    TRISC
        MOVLW    B'00001110'
        MOVWF    TRISB
        MOVLW    B'00000001'
        MOVWF    TRISD
        BANK0
        CLRF    PORTC
        CLRF    PORTD
        CLRF    PORTB
;DELAY SUBROUTINE
DELAY1        MOVLW    FFh
            MOVWF    20h
            MOVLW    FFh
            MOVWF    21h
DELAYLOOP    DECFSZ    20h
            GOTO    DELAYLOOP
            DECFSZ    21h
            GOTO    DELAYLOOP
            RETURN
;MAIN PROGRAM START HERE
;LCD INITIALIZED
            CALL    DELAY1
            CALL    DELAY1
            BCF        PORTB,6                ; R/S SET TO '0'as a command
            MOVLW    B'00110000'
            MOVWF    PORTC                ; FUNCTION SET: 8 BIT INTERFACE
            CLOCK_E                        ; E CLOCK MACRO
            MOVLW    B'00001101'
            MOVWF    PORTC                ; DISPALY & CURSOR: SET TO DISPLAY ON; CURSOR UNDERLINE OFF; CURSOR BLINK ON
            MOVLW    B'00111000'
            MOVWF    PORTC                ; FUNCTION SET: 8 BIT; 2 LINE MODE; 5X7 DOT FORMAT
            MOVLW    B'00000001'
            MOVWF    PORTC                ; CLEAR DISPLAY
            MOVLW    B'00000110'
            MOVWF    PORTC                ; CHARACTER ENTRY MODE: INCREMENT; DISPLAY SHIFT ON
;WRITE YOUR CHARACTER HERE
            BSF        PORTB,6        ;R/S SET TO '1' to write character
            MOVLW    B'01010110'        ;'V'in ASCII mode
            MOVWF    PORTC            ;Display 'V'
            CLOCK_E
            MOVLW    B'01001111'        ;'O' in ASCII mode
            MOVWF    PORTC            ;Display 'O'
            CLOCK_E
            MOVLW    B'01001100'        ;'L' in ASCII mode
            MOVWF    PORTC            ;Diplay 'L'
            CLOCK_E
            MOVLW    B'01010101'        ;'U' in ASCII mode
            MOVWF    PORTC            ;Display 'U'
            CLOCK_E
            MOVLW    B'01001101'        ;'M' in ASCII mode
            MOVWF    PORTC            ;Display 'M'
            CLOCK_E
            MOVLW    B'01000101'        ;'E' in ASCII mode
            MOVWF    PORTC            ;Display 'E'
            CLOCK_E
            MOVLW    B'00111010'        ;':' in ASCII mode
            MOVWF    PORTC            ;Display ':'
            CLOCK_E
            MOVLW    ' '                ;' ' in ASCII mode
            MOVWF    PORTC            ;Display ' '
            CLOCK_E
I dun know how to declare and activate ultrasonic sensor part using Timer1,CCP1,the division formula, and to display the answer in lcd
I found an example from internet,but I dun understand the coding.......hope this useful, thx for help
  • try.txt
