[help] Analog Environment of !c50
fatbear
Junior Member level 3
There are my questions:
1.
When I click "Setup-->Simulator/Directory/Host", "hsp!ce" is not listed in the simulator's menus, but there is a simulator named "hsp!ceS", I wonder that 1) Is there a "hsp!ce" in the simulator's menus when clicking "Setup-->Simulator/Directory/Host"? 2) What program is called by this "hsp!ceS" when it runs? if is the "hsp!ce" of Syn0psys called?
2.
When I click "Setup-->Simulator/Directory/Host", select "hsp!ceS", and then click "Setup-->Model Path", there is a default path named "$home/models" ($home is the home name of the user), because there is no such path, and I want del this model path and add a new path which contains the models. But "$home/models" cannot deleted from the list? I don't know why and how to solve this problem?
Thanks!
"hspiceS" in IC5 is the link to hspice from Synopsys. It will work only if you have already installed and configured the "real" Synopsys hspice to work within your machine.
If your Hspise is highlight and the env is right, the simulator shall be the spice of the synopsys.
