help: ads simulation error
gargoyle
Junior Member level 3
hello all:
i encounted a queation during my ads simulation, when i use subcircuits
i defined myself, it always give error " syntax error in component call; define rnod(n1 n2)"
i checked the subcircuit but did not find error.
i want to know what is the reason. thanks
gargoyle
I'm not sure, but do you have any test/probe points in your sub circuit?
The names might be conflicting. Also take out any "var" from the sub circuit
and replace them with constants just to be on the safe side.
hope this helps.
Peace
Re: help: @DS simulation error
hope this helps.
Peace
i checked that, now even when there is only one moefet in the subcircuit, the
error still exists. i think maybe it is the problem of the design kit :(
