Help ADS Document for MMIC PA Design
pusparaga
Full Member level 4
Full Member level 4
Like ADS CookBook, is there any help document available for Power Amplifier(PA) Design using MMIC Technology. In ADS CookBook, good example has given to desIgn PA at 1 GHz using Microwave Integrated Circuit (MIC).
Like ADS CookBook, help document available for design at any band PA design using MMIC technology. If anybody has help document, can you share.
Discrete OR MMIC OR RFIC, no matter Technology/Process you've been using, the Main Principles of Designing of an Power Amplifier are always same.
There are some different tricks or methods but they are essentially same.
I have attached MMIC ADS design document and Screen related to MMIC design of Amplifier. It looks similar to Microwave Integrated Circuit (MIC) design implementation. But in MIC Amplifier design, lumped values of resistance , capacitors and inductors are separated by using MLIN with larger width and length. After completing this, we are generating Gerber file and send it to Fabrication.
In MMIC Design, are we growing resistors, inductors and capacitors on the monolithic layer. What is the major difference between MIC and MMIC?
In MMIC design, are we using design kit values of L, C and R values. To separate these L,C and R , we are small using MLIN with small um width and length. Is it right, later we are generating Gerber file for layout.
  • MMIC_CKT.pdf
  • Input matching circuit schematic, with design kit elements and a DC bias network.jpg
  • The interstage matching network, including design kit elements and DC bias inductors.jpg
  • 5988-9637EN_2_MMIC_ADS_Design.pdf
LaTeX Commands Quick-Menu:
