Help adding load to microstrip TL in FEKO
Sadie Brasel
Newbie
Newbie level 1
Hello,
I am simulating a U-Slot micro path antenna in FEKO and I am feeding it with a 50 ohm transmission line that runs below the ground plane. In series with the TL is a tuning capacitor. When I run my simulation I get an error concerning incorrect application of a load:
The following message from the server process (MYID= 1):
ERROR 38238: Incorrect application of a load/excitation/non-radiating network port connection to a microstrip edge between two points
See also message in the output file u_slot_patch_fr_1_ada_1.out
ERROR 31061: ADAPTFEKO run will terminate now due to error in RUNFEKO
My .cfx file has been attached, any help is greatly appreciated. Thanks!
  • U-Slot.zip
